dhananjoy chowdhury Wed, 07/16/2008 - 21:40
  • Silver, 250 points or more
On the Cisco ACS console >> on the left panel there is a tab " Reports and Activity"
Under that you will find all reports like
- Passed Authentications
- Failed Attepmts
- Logged in users
and lot more options.
Hope this helps.
darpotter Thu, 07/17/2008 - 00:00
Unfortunately ACS does not store the account creation date in its DB.
You can get the last authentication date (if you have password aging enabled) from the database, otherwise you have to use accounting data instead.
Take a look at our app - extraxi aaa-reports! which can import the ACS user dataabse directly and report on all this stuff.
Also our new csvsync v3.0 can pull the ACS support cab (incl the DB) right off the ACS server ready for import.
