Cisco 857 - Hairpinning
How would I go about enabling hairpin routing?
I need the Cisco to take a packet from an internal device that's destined for the Di0 IP to be forwarded back internally according to the existing port forwarding rules.
No-one seems to know how, surely there's a guru out there that knows how to get it done!
(Current config attached)
Marwan ALshawi Wed, 07/16/2008 - 21:09
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
try to make an loopback interface and make nat insdie
on this loopback make apply a route map the redirect matched traffic by an acl to use an exit interface in the set command statment
*not sure about it
but, good luck
if worked rate :)
