IPCCX6.0 SQL 200 DB Installation
Jul 16th, 2008
It is recommended that for high availability SQL2000 is used instead of MSDE2000(default DB with IPCCX).
If at the time of installtion IPCCX6.0, MSDE2000 was used. At some point later, is it possible to change the DB to SQL2000 later?
If yes how complicated it is, does it insvolve reinstalltion of IPCCX?
Chad Stachowicz Thu, 07/17/2008 - 15:59
ra,
You can run the MSSQL disc at anytime to upgrade it with 0 problems. I suggest pulling a drive and taking a backup first, but no problems otherwise with upgrading SQL..
However I know that you choose First node or Single Node at the intial setup. I bet TAC can fix this with CETTool and manually creating the publication.
Just some thoughts!
Chad
