07-17-2008 12:06 AM - edited 03-15-2019 12:01 PM
I need some one to help me on how to configure my MGCP gateway to receive calls from the PSTN. i can dial out to the PSTN perfecctly well.
i want to the call to go to a receptionisyt desk who route it to the desired extension.
i use call manager 6.1 and cisco 3845 as the gateway.
Kindly help out
thanks in advance
07-17-2008 12:19 AM
Go to your gateway in callmanager, scroll down to the incoming calls section,
In the digits section put in the number of youe internal extension digits eg if your extension are say 4005 you should put 4 as the signicant digit.
In the CSS (caling search space) select a CSS that has the partition of your internal phones in it.
You should be good with this
10-13-2008 08:38 AM
I am facing the same, searched the topic 'Inbound at MGCP' and found the same, it's better than opening a new one, right?
I am facing the issue, I will not say it as problem but lack of configuration in my CCM. I am using CCM 4.2 with 2811.
I couldn't find the incoming section at gateway configuration section, may be it's absent at 4.2. I found an option for direction whether it would be inbound/outbound/bothways.
How can I receive my incoming calls from PSTN to my IP phone at MGCP?
Thanks in advance. Your help will be highly appreciated.
10-13-2008 11:01 AM
what are you using for inbound calls?? PRI? FXO? MGCP?
if you click on the GW then you click on endpoints and you will see the incoming sections, it is on 4.2 and in all versions
java
if this helps, please rate
10-13-2008 08:12 PM
10-14-2008 07:08 AM
for FXO configure the attendant DN to tell which phone should ring when a call comes in thru that FXO
java
10-14-2008 07:31 AM
Thanks for you guidance. Yes, I did set the 'Attendant DN' exactly like a phone DN (10004),but getting something strange. The port is receiving the call, getting muted and after 15 seconds the call drops. IP phone don't ring in this muted time. Am I missing something?
I am not using no CSS, so nothing is there with permission.
I've tried the same with issuing the command 'mgcp bind control', but received the same. Also reseted the gateway, port...I can find the FXO port at 'sh mgcp end'.
Is there any dependency on routing? I am using a sub-interface in the gateway to work as gateway.
(i have attached my gateway config)
10-14-2008 07:50 AM
this the port you're using??
dial-peer voice 999001 pots
service mgcpapp
port 0/0/1
anyway if the endpoint does not show when issuing show mgcp endpoints first thing to get fixed is the registration, probably also shows as unregistered in CUCM. you have to check your MGCP config and get it registered before moving forward with call routing
java
10-14-2008 07:56 AM
Again, I can do find the endpoint. It's registered well, i can make outbound calls also.
LAB_VGW#sh mgcp end
aaln/S0/SU0/1@LAB_VGW
LAB_VGW#sh ccm
MGCP Domain Name: LAB_VGW.ipcclab.dhk
Priority Status Host
Primary Registered LABCCM (10.234.155.203)
First Backup None
Second Backup None
Current active Call Manager: 10.234.155.203
Backhaul/Redundant link port: 2428
Any idea please?
10-14-2008 08:01 AM
And also, yes I am using the port:
service mgcpapp
port 0/0/1
I didn't created this pots dial-peer, it was created automatically while configuring from CCM.
10-14-2008 09:40 PM
Now the CCM prompting the known unreachable media 'Your call cannot be completed.....'
Any other configuration am I missing?
