PRI Splitting
Jul 17th, 2008
I believed what I want to do is call PRI Splitting
What happened is that my customer had one range of number:
64179500 to 64179519
now, the range is not enough, and the provider give them
65129500 to 65129519
How can i configure this on a CCME, so that CCME will recongnize both set of number and pass to the respective user?
First set of user extension: 500 - 519
Second set of user extension: 600 - 619
Is this possible?
Yen Lung
Paolo Bevilacqua Thu, 07/17/2008 - 00:28
you can number you extension so you have 500-519 and 600-619, or you can translate the second DID block to extensions 520-539.
Basically, you can do as you like better.
Please rate post if it helps!
yenlung Thu, 07/17/2008 - 00:33
Is there any special command to input into the system due to splitting of numbers on the PRI ?
yenlung Sun, 07/20/2008 - 18:38
Will aprreciate if you could help a sample config.
Yen Lung Mon, 07/21/2008 - 02:16
How are you doing this for the first set of DID's, can you not use the same method for the new range?
Or is the telco only presenting the last 3 digits, if so you will need the telco to present 8 digits.
