Cisco ASA and Watchguard VPN SA Re-Key Errors
Jul 17th, 2008
Greetings we are running a Cisco ASA 5510 with 8.0.3(19) code and have several site to site vpn connections for various partner access.
One partner is using a Watchguard x550e, the site to site tunnel is configured as follows:
IKE Phase 1: 3Des/Sha/DH Group 2
IKE Phase 2: 3Des/Sha/DH Group 2
IKE is using aggressive mode and PFS has been disabled.
The VPN establishes just fine and stays up for the set SA Lifetime being the default of 8 hours, but when the 8 hour limit is reached the VPN drops out and cannot re-key and re-establish the connection, in order to get the connection back up the link has to be torn down at one end and re-created manually.
This is what happens after the 8 hour period.
Group =, IP =, Received non-routine Notify message: Payload malformed (16)
Group =, IP =, De-queuing KEY-ACQUIRE messages that were left pending.
IP =, Keep-alives configured on but peer does not support keep-alives (type = None)
AAA retrieved default group policy (DfltGrpPolicy) for user =
Group =, IP =, Automatic NAT Detection Status: Remote end is NOT behind a NAT device This end is NOT behind a NAT device
IP =, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
IP =, IKE Initiator: New Phase 1, Intf inside, IKE Peer local Proxy Address, remote Proxy Address, Crypto map (OutsideMap)
Group =, Username =, IP =, Session disconnected. Session Type: IKE, Duration: 0h:00m:32s, Bytes xmt: 0, Bytes rcv: 0, Reason: Phase 2 Error
Group =, IP =, Removing peer from correlator table failed, no match!
Group =, IP =, construct_ipsec_delete(): No SPI to identify Phase 2 SA!
Group =, IP =, QM FSM error (P2 struct &0xd8e9a790, mess id 0x16ee7a8c)!
Would anyone have any suggestions as to what the cause might be?
Daniel Voicu Thu, 07/17/2008 - 05:46
There are two SA lifetimes: for Phase1 and for Phase2.
Both should match on both ends.
IKE lifetime:
crypto isakmp policy 10
lifetime 86400
IPSEC lifetime:
crypto map VPN 10 set security-association lifetime seconds 28800
Also, you should configure the main mode instead of aggressive:
crypto map VPN 10 set phase1-mode main
Please rate if this helped.
