VIP card can't be recognized!!!
Jul 17th, 2008
after i remove the vip card and pugin into the slot, it can't be recoginzed and fail to work.
00:01:19: %VIP4-80 RM7000-3-MSG: slot5 VIP-3-SVIP_RELOAD: SVIP Reload is called.
00:01:19: %VIP4-80 RM7000-3-MSG: slot5 VIP-3-SYSTEM_EXCEPTION: VIP System Exception occurred sig=22, code=0x0, context=0x608B3708
00:01:30: %CBUS-3-CCBPTIMEOUT: CCB handover timed out, CCB 0x5800FF70, slot 5
-Traceback= 6045835C 604557D8 60455E9C 6044CB08 603C28C8 60303D2C 60303F48 603A02E4 603A02D0
00:01:30: %PPP-4-NOREGISTER: NCP not registered, protocol = 0
how would i make it back to normal?
thands
n.nandrekar Thu, 07/17/2008 - 02:41
  • Silver, 250 points or more
The VIP supports OIR and just removal and insertion shouldnot have caused any problem. You can try hw-module reset for the VIP or reload of the chassis if possible. Else you would have to open a TAC case giving the traceback you have seen.
Is there any chance of h/w failure? ( i mean did you handle the VIP or touched anything inside without wearing anti-static band?
Niranjan
