PPPoE on an 871 help
Jul 17th, 2008
I am trying to set up an 871 router to connect to DSL over PPPoE. As far as I can tell, it is set up correctly, but it doesn't look like it is negotiating properly. I have attached the config as well as the output from the debug ppp negotiation.
Am I missing something in the cofiguration? I am not real familiar with DSL.
pmccloud Thu, 07/17/2008 - 04:40
I am not worried about NAT, I can add that once I get the DSL up and running. I configured both PAP and CHAP as I don't know which one Bell South uses, and the tech support person I spoke with couldn't tell me.
Marwan ALshawi Thu, 07/17/2008 - 04:52
this is a sample config use it as refrence
CPE!ip dhcppool MyPool
network 10.0.0.0 255.0.0.0
default-router 10.0.0.1
interface Ethernet0/1
no ip address
pppoe enable
pppoe-client dial-pool-number 1
interface Ethernet0/0
ip address 10.0.0.1 255.0.0.0
ip nat inside
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
ip mtu 1492
ip nat outside
ppp authentication chap callin
pppchap password mysecret
ip nat inside source list 101 interface Dialer0 overload
access-list 101 permit ip 10.0.0.0 0.255.255.255 any
ip route 0.0.0.0 0.0.0.0Dialer0
rate if helpful
