SSL Certificate expiry for VPN Concentrator
Jul 17th, 2008
The VPN Concentrator SSL Certificate has been expired and i am trying to find out if it is fine to renew the same via the Administration > Certificate Management on the SSL section. First delete and then Click the renew option, and that renews the SSL certificate.(Attached is the snapshot)
Also please let me know if the certificate expires what all i wont be able to do and whether any impact will be there if i renew the certificates
Ankur
srue Thu, 07/17/2008 - 09:15
the certificates in the picture you attached don't expire until 10/15/2008. ie, they're still good.
ankurs2008 Thu, 07/17/2008 - 09:34
dear srue
the attached snapsot is just an example.i m talking about the actual situation
my actual quest is:
Please let me know if the certificate expires what all i wont be able to do and whether any impact will be there if i renew the certificates
Ankur
