unity error 404
Jul 17th, 2008
One of client place i am facing one error, i am not able to open the unity web page, i getting error 404. all unity services are working finaly, and i restarted the iis service also. once i restart the server also. then also its not comming up. and one also i tried i try to browse from the iis dirctly then also i getting the same error.
sunish
thfergus Thu, 07/17/2008 - 06:12
  • Cisco Employee,
Can you launch the Unity Status Monitor web page by right-clicking on the Unity icon in the system tray? If not, check for the presence of the Unity virual directories under IIS.
sunishnair Thu, 07/17/2008 - 21:32
I tried to launh the unity sataus monitor also, but i am getting the same error only. I try to dirctly start from the IIS also. Then also i getting the erro 404. For the testing pourpose i created one virtual dirctoy also, that is working i think so. I think this problem related to with some Security settings, because that testing virtual directory created with out HTTPS, its only HTTP. so any other option i want to do. can you please update me the same one
sunish
vinhnguyen Thu, 11/06/2008 - 17:10
Did you find the resolution for this? I am getting the same issue.
sunishnair Thu, 11/06/2008 - 22:02
hi vinhnguyen,
I am not able to find any solution for this problem. We reinstalled the Unity.
Can you check in Microsoft website also, they are providing some steps to resolve this problem.
Sunish
