VWIC2-2MFT-T1/E1 ethernet card
Jul 17th, 2008
  • Gold, 750 points or more
I have a VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on cisco router 2801. what interface to setup for this card?
Overall Rating: 4.7 (11 ratings)
paolo bevilacqua Thu, 07/17/2008 - 05:45
  • Hall of Fame,
    Founding Member
That is not an ethernet card, it is a WAN or Voice T1/E1 card. What do you need to do ?
francisco_1 Thu, 07/17/2008 - 06:04
it got two ethernet port. need combine them as a single E1 circuit
WIC/VIC/HWIC Slot 1:
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : B0
Deviation Number : 95966
Fab Version : 04
PCB Serial Number : FOC12220LH6
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
0x10: 42 42 30 88 00 01 76 DE 02 04 C1 8B 46 4F 43 31
0x20: 32 32 32 30 4C 48 36 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
paolo bevilacqua Thu, 07/17/2008 - 06:10
  • Hall of Fame,
    Founding Member
Hi, ethernet is the LAN thing, the connector with 8 pins is called RJ-45 and sometime RJ-48.
Do you have the circuit active and delivered already ?
francisco_1 Thu, 07/17/2008 - 06:12
yes circuit is active connected to a MUX. just need to setup the VWIC card on the router and combine both E1's as a single circuit
paolo bevilacqua Thu, 07/17/2008 - 06:21
  • Hall of Fame,
    Founding Member
card type E1
network-clock-participate wic
network-clock-select 1 E1 /0
network-clock-select 2 E1 /1
controller E1 0//0
channel-group 0 timeslots 1-31
controller E1 0//1
The serial interfaces will appear, configure as usual with DEFAULTS, I recommend that initially you do NOT use multilink PPP to test the circuit first, after that you can look into "combining".
francisco_1 Thu, 07/17/2008 - 06:29
i only have one card in slot 1
paolo bevilacqua Thu, 07/17/2008 - 07:50
  • Hall of Fame,
    Founding Member
Then replace with 1 and enter the commands above.
As an appreciation for those providing answers, please rate useful posts with the scrollbox below!
francisco_1 Thu, 07/17/2008 - 07:50
paolo,
i now have
controller E1 0/1/0
controller E1 0/1/1
interface Serial0/1/0:0
no ip address
interface Serial0/1/1:0
no ip address
i gues i need to use multilink ppp to combine both serial sub interfaces right?
francisco_1 Thu, 07/17/2008 - 07:52
so both CTRLR E1 0 and CTRLR E1 1 now appears how the serial interfaces. right?
do you have a sample config to combine both cards using multilink ppp or should i just use EIGRP?
is66rlhntadm Thu, 07/17/2008 - 08:33
  • Bronze, 100 points or more
1. they may look like rj-45's (which you think is ethernet but their not ethernet)
the card is a dual port channelized e1/t1 card
are they connecting to an MPLS or to the internet
if MPLS then eigrp could load balance but if its an internet connecting the multilinkPPP should be the way
paolo bevilacqua Thu, 07/17/2008 - 08:42
  • Hall of Fame,
    Founding Member
use eigrp for now and test the circuits to be perfectly clean for few days. Then if you don't like performances or anything you can do mlppp, but you need to configure the router on the other side as well.
Please remember to rate useful posts.
francisco_1 Thu, 07/17/2008 - 08:46
haved used mlppp.
controller E1 0/1/0
framing NO-CRC4
controller E1 0/1/1
framing NO-CRC4
interface Multilink1
ip address **********************
no cdp enable
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
bandwidth 2048
no ip address
encapsulation ppp
no cdp enable
ppp multilink
no ip address
encapsulation ppp
no cdp enable
ppp multilink
have i missed anything? will eigrp just see mlppp interface or both serials? how about using CEF?
paolo bevilacqua Thu, 07/17/2008 - 08:59
  • Hall of Fame,
    Founding Member
Seems ok. Check "show controllers E1" to see what how the circuits are doing.
Note unless you configure mlppp on the other end too, nothing will work.
You have not rated any post so far, it is customer to do so as an appreciation for the frre help received.
francisco_1 Thu, 07/17/2008 - 09:10
paolo i appreciate your help and i have rated you. sometimes i go through a lot to help someone with their questions and they never receive any ratings.
I think this site should have rules about rating.
Thanks for your help today.
Francisco.
paolo bevilacqua Thu, 07/17/2008 - 09:14
  • Hall of Fame,
    Founding Member
Ultimately rating is left to the fairness of the person.
I don't mind reminding people because I have a direct approach to everything.
Thanks and good luck!
itakenishi Wed, 07/23/2008 - 10:13
Hello All,
I don't mean to thread jack but I have a question that pertains to this hardware device. I have a Cisco 2811 routers, and WIC-1DSU-T1-V2 cards. The customers budget is only allowing for two more T1's; I was thinking of purchasing the VWIC-2MFT-T1 cards. My question is will the VWIC card work with my router and will I be able to multilink these two different types of cards together and across multiple serial interfaces?
Thanks for your help in advance.......
