ACS external database question
Jul 17th, 2008
our customer need a security solution that enable the users to login to the wireless network with their usernames & the passwords which stored in the active directory not using the preshared key of the wireless.
if we are using ACS server and integrate it with the active directory , this will enable the users to login with their usernames and the passwords or not ????
Also our customer use D-Link access points . These access points must be replaced with cisco access points or it can be used with the ACS.
please i need your help.
regards
Jagdeep Gambhir Thu, 07/17/2008 - 11:05
  • Red, 2250 points or more
Important thing here is to check if D-link AP supports EAP authentication (PEAP- TLS ).
If it has that feature then it should work with acs.
~JG
mohamed_makled Thu, 07/17/2008 - 11:19
Hi JG
Thanks for your mail . ok i will check that but i need to know if it is possible for the users to login with their usernames and passwords stored in the active directory instead of the preshared key or not ???
