Need some one help
Jul 17th, 2008
Iam trying to adding the PIX firewall to my newly installed the ACS server.
after adding all the required commands still i am unable to access the firewall using local user only.
my firewall is already having some aaa commands earlier. and i am unable to clear that lines.
PIX515# sh run | inc tacacs
aaa-server TACACS+ protocol tacacs+
PIX515# sh run | inc aaa
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
some body please help me how to delete the above commands and what are the command that i have to place.
Pix Version:
Cisco PIX Firewall Version 6.3(4)
dhananjoy chowdhury Thu, 07/17/2008 - 09:39
Hi, these are the commands yo need
aaa-server TACACS+ host cisco
aaa authentication http console TACACS+ local
aaa authentication ssh console TACACS+ local
aaa authentication telnet console TACACS+ local
Also create a local admin user =
username admin password admin privilege 15
Now, to delete the old code, if you have not done "write mem" then a reboot will do.
or else you will have to follow the procedure given in this link :
chaitu_kranthi Fri, 07/18/2008 - 18:13
i can able to login to the device using local username & password. i.e. telnet iam able to login.ssh is not allowing me.
now tell me how can remove the previous commands with out rebooting the device.
