MGCP, CCM and 3845 routers
Jul 17th, 2008
We're using CCM 4.1 with a 3845 to create an MGCP gateway. We keep running into an issue because somehow the CCM hostname keeps getting inserted into the MGCP config in the router even though we programmed it as an IP address. Because of this we keep getting a domain name issue and the gateway will not register. We've used a "no ip domain lookup" command, which is still in there, but it doesn't seem to have any effect.
Jaime Valencia Thu, 07/17/2008 - 07:00
remove the line ccm-manager config server to avoid that
javalenc
if this helps, please rate
tdodenhoff@dvfs.com Thu, 07/17/2008 - 09:00
Thanks! That seemed to work perfectly. Now, we're having a problem with the controller coming up so the MGCP gateway will not register properly. We'll figure it out, I guess.
