Unity 5 - Listening to voicemails via webpage
Jul 17th, 2008
Is this possible to do?
Overall Rating: 4 (1 ratings)
tim.giles Thu, 07/17/2008 - 06:58
Yes, you can do this via OWA and listen to the .wav files in Outlook....
Please rate post....
Tray Stoutmeyer Thu, 07/17/2008 - 07:11
Which webpage are you talking about? If it's OWA, then yes see the last post. However, if you are talking about Unity Inbox, yes, you can do it there too. Can you give us a little more detail of your question so we can answer it more directly?
honniesr Thu, 07/17/2008 - 08:34
Our system is setup with no integrations at this time. Our email is GroupWise.
I saw that you should be able to hit some type of webpage via CiscoPCA, but the only option I see available is "Cisco Unity Assistant", not an inbox option.
Tray Stoutmeyer Thu, 07/17/2008 - 08:48
Well to be able to view the Unity Inbox you have to be licensed for it and also have subscriber COS set to use it.
honniesr Thu, 07/17/2008 - 08:50
ah..it's a purchased product. I sent off an email to our Cisco rep last week and no response. :(
ranpierce Thu, 07/17/2008 - 09:07
yes it requires licensing, however any COS can be used just check the Unity Inbox check box in the features of that COS.
Not just subscriber COS.
