How to send an octothorpe '#' character
Jul 17th, 2008
my customer has an special need that some DNIS terminate with the # character. The issue is that callmanager uses this character as end of dial string and strip off before sent to the gateway (in my case H.323).
Anyone know, how can I send the '#' character? And if the voice gateway will discard this '#' character too!
Best Regards
Paolo Bevilacqua Thu, 07/17/2008 - 07:55
  • Hall of Fame,
    Founding Member
Configure:
dial-peer terminator '0'-'9', 'A'-'F', '*', or '#'
or
no dial-peer terminator
Please rate post if it helps!
Fabio Funaki Fri, 07/18/2008 - 06:22
I cannot test yet because apparently the '#' digit is not being sent by CallManager to the voice gateway.
Best Regards
kgroves42 Thu, 07/17/2008 - 10:10
There is also a Service Parameter called "Strip # Sign from Called Party Number Required Field" That by default is set to true in the Call Managers Service Parameter field
Fabio Funaki Fri, 07/18/2008 - 06:20
Hi, I have configured this parameter and looking in the depug vpm signal output, I cannot see the '#' digit in the DNIS.
Best Regards
Paolo Bevilacqua Fri, 07/18/2008 - 06:23
  • Hall of Fame,
    Founding Member
How the call is coming into the router? Perhaps the # doesn't arrive to it at all.
Fabio Funaki Fri, 07/18/2008 - 07:25
The call control between CCM and the Voice Gateway is H.323.
I have an Route Pattern in CallManager for International calls with the pattern: "0.00[1-9][1-9]!#", CCM is not discarding any digit.
This pattern is associated with an Route List and the Route List with an Route Group. None of this elements performs transforms in called number.
Best Regards
