Easy VPN problem
Jul 17th, 2008
Hello, a costumer is trying to connect to our concentrator from a linux box with the vpn cisco client for linux and we are getting this output on the 2800 debug: (see attached file )
Any hints ? Thank you !
Overall Rating: 3 (1 ratings)
Daniel Voicu Thu, 07/17/2008 - 07:45
It appears to be a user credential issue:
*Jul 17 15:11:17.376: ISAKMP:(4274):Input = IKE_MESG_FROM_AAA, PRESHARED_KEY_REPLY
*Jul 17 15:11:17.376: ISAKMP:(4274):Old State = IKE_R_AM_AAA_AWAIT New State = IKE_R_AM2
For a config verification check:
Please rate if this helped.
godzilla0 Thu, 07/17/2008 - 07:51
What you mean with "credential" that's pretty cryptic for me. Could you explain what kind of problem may be involved ¿?
Daniel Voicu Thu, 07/17/2008 - 07:56
Ok, for Easy VPN you have a group name and password, and then you have a username and password for to authenticate the user.
I think at this moment the user is not using the correct password. Have you configured any TACACS/RADIUS authentication or you configured the users/pass using "username" command on the rotuer?
godzilla0 Thu, 07/17/2008 - 08:04
We did with all the config with "username".
But the costumer is trying with the right pass . . I think is another kind of problem . .
Daniel Voicu Thu, 07/17/2008 - 08:30
Can you attach the router config (but remove all the public IPs and the passwords).
