Generating PDF reports
Jul 17th, 2008
Is there any way to generate the MARS reports in PDF format? I need to send the reports in a readable compact format to colleagues and customers. The current format brings my Thunderbird mail client to a crawl so I imagine it's too big. If it can't be done, can someone suggest a good free or commercial converter to use (with the print to file option)?
Thanks, Joe
Overall Rating: 4 (1 ratings)
joe.favia Thu, 07/17/2008 - 23:58
Yes, I know, thare are many. That's why I asked if anyone could suggest a GOOD one that won't chop off page margins or interpret graphics correctly, etc.,etc. I've tried a few but so far they are all lacking in some aspect. Thanks anyway,
Joe
mhellman Fri, 07/18/2008 - 04:52
  • Blue, 1500 points or more
Well, I've had good luck with htmldoc on Linux (http://www.htmldoc.org/). However, I've never tried a complicated page like those produced by MARS. You might try the trial version of Adobe Acrobat and see how it looks.
clausonna Mon, 07/21/2008 - 06:13
  • Bronze, 100 points or more
PDF995 has been around for a while and is free and fully-functional with no expiration. It does have a nag window each time you print, but $10 for a license fixes that. I'm not sure if it plays well with MARS, though.
lundvall Mon, 07/21/2008 - 13:27
Joe:
I use cutePDF printer that was mentioned earlier for exactly what you mentioned. I print monthly reports to PDF files using CutePDF and I don't have any issues with margins etc.
