caller id name not working b/w CM & Avaya 8700
Jul 17th, 2008
we have CM 5.1 with 2811 mgcp gateway running isdn qsig to Avaya s8700. Caller id name is not passing between Avaya & Cisco in both direction.
Overall Rating: 5 (2 ratings)
paolo bevilacqua Thu, 07/17/2008 - 12:28
  • Hall of Fame,
    Founding Member
There should be a setting in CM regarding qsig version, try changing that.
Chad Stachowicz Thu, 07/17/2008 - 15:50
  • Silver, 250 points or more
well the encoding needs to BE ISO, if its ROSE I don't think CM will give you calling name..
Chad
vilpatel3 Tue, 07/22/2008 - 09:30
Thanks for all your reply,
I found that we have Avaya Definity System with S8700 & found configuration documentation :
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/410364av.pdf
What I found that Avaya side is configured for Qsig ; Basic Supplementary Services is not enabled (System Parameter & Customer options) .
I also found this document ( http://www.svcc.cc.il.us/UserMenu/employees/telephone/images/buttons.pdf Page 362) about Supplementary Service protocol value which most likely change which Qsig Avaya side use.
Once again thank you all , will let you know if things work .
