Bad Flash in ASA, no smartnet either.
Answered Question
Jul 17th, 2008
when I do a dir on my ASA 5505 I get the following error.
%Error opening disk0:/ (Invalid DOS media or no media in slot)
I assume this mean it is bad because it is installed. Does anyone know if I can just buy a flash card and install it do does this have to come from Cisco. If it comes from Cisco they run about $400.00 and I will just have to buy a new ASA for $600.00.
Dan
Correct Answer by srue about 9 years 1 week ago
www.lanstreet.com sells 5505's for a very reasonable price.
so the 5505 is currently booted up into an OS?
have you tried formatting the flash?
have you tried copying an image to flash?
Overall Rating: 5 (1 ratings)
Correct Answer
srue Fri, 07/18/2008 - 20:30
  • Blue, 1500 points or more
ddevecka Mon, 07/21/2008 - 06:01
Formatting the Flash has fixed the issue.
Dan
