udld message timer
Answered Question
Jul 17th, 2008
  • Bronze, 100 points or more
hi everybody!
could anybody please explian if we can configure udld message timer in interface configuration mode i.e
switch(config-if) udld{ enable/aggressive/disable}
i dont see any message timer option in interface mode. Is it only avaiable in global configmode ? i.e
switch(config) udld {enable/aggressive/message time}
another question is how we disable the normal mode for example
switch(config)udld enable
should i disable it using no i.e
switch(config) no udld enable
how to turn off udld normal mode in interface mpde ? i.e
switch(config-if) udld enable
should i disable it using:
switch(config-if) udld enable disable
or
switch(config-if) udld disable.
Can we use "no" form to disable it? i.e
switch(config-if) no udld enable.
thanks a alot and have a nice day!
Correct Answer by smahbub about 8 years 11 months ago
To enable UniDirectional Link Detection Protocol (UDLD) on the interface or enable UDLD in aggressive mode on the interface, use the udld port command in "Interface Configuration Mode". To return to the default settings, use the no form of this command.
Overall Rating: 5 (1 ratings)
Correct Answer
smahbub Wed, 07/23/2008 - 13:00
  • Silver, 250 points or more
