Timeout time? FTP issues
rygar1234
Hi everyone do i need to set timeout time on an inspection command and how long it should be set at?
ip inspect name SDM cuseeme
ip inspect name SDM dns
ip inspect name SDM ftp
ip inspect name SDM h323
ip inspect name SDM icmp
ip inspect name SDM imap
ip inspect name SDM netshow
ip inspect name SDM rcmd
ip inspect name SDM realaudio
ip inspect name SDM rtsp
ip inspect name SDM esmtp
ip inspect name SDM sqlnet
ip inspect name SDM streamworks
ip inspect name SDM tcp
ip inspect name SDM udp
ip inspect name SDM vdolive
For example if I am having issues with ftp downloads timing out I tried (below) but ftp sessions still time out ... any ideas?
ip inspect name SDM ftp timeout 3600 ?
Thank you
smahbub
Level 6
Level 6
If you specify a timeout for any of the transport-layer or application-layer protocols, the timeout will override the global idle timeout for the interface to which the set of inspection rules is applied.If the protocol is TCP or a TCP application-layer protocol, the timeout will override the global TCP idle timeout. If the protocol is UDP or a UDP application-layer protocol, the timeout will override the global UDP idle timeout.If you do not specify a timeout for a protocol, the timeout value applied to a new session of that protocol will be taken from the corresponding TCP or UDP global timeout value valid at the time of session creation.
