Sync Archive Failed
Jul 17th, 2008
Hi all,
I am getting the following message when I try a sync archive. Does anyone no what could be the reason. Credentials seems to be all right.
Protocol ==> Telnet
CM0057 PRIMARY RUNNING Config fetch SUCCESS, archival failed for akl-application Cause: CM0002: Could not archive config Cause: Device may not be reachable, may be in suspended state or credentials may be incorrect. Action: Verify that device is managed, credentials are correct and file system has correct permissions. Increase timeout value, if required. Action: Verify that archive exists for device. CM0060 VLAN RUNNING Config fetch SUCCESS for akl-application, version number 1412 archived.
Overall Rating: 5 (1 ratings)
