cme 4.1
Jul 17th, 2008
I installed cme 4.1 using the tar xtract. The phone files are now in a directory phone/79xx-79xx/
I serve them up with tftp-server poinint to the directory but when the phone attempts to find the file nothing
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 07/18/2008 - 00:18
After directory/filename, use the alias keyword with the filename. Eg:
tftp-server flash:/phone/term41.default.loads alias term41.default.loads
Please rate post if it helps!
whanson Wed, 07/23/2008 - 08:30
I gave top rating thanks much. I can't understand why Cisco changes the way the ship the stuff. If you go to the download section it is now just a series of zip files that you have to move to flash; very dull, if you go get the tar files it puts the files in directories unless there is a magic xtract parm to eliminate this, now you are stuck with adding alias to every tftp-server entry. AAARRRGH
