07-17-2008 06:29 PM - edited 03-03-2019 10:47 PM
is there any command in a router where I can see the daily, weekly, monthly utilization of the port? thanks
07-17-2008 10:15 PM
I dont think there is any such command.
Better use NMS tools like OpenNMS and configure SNMP.
07-18-2008 05:33 AM
Bandwidth utilization is polled by using an NMS (network monitoring system).
This is done by using SNMP and querying the MIBs on network devices.
If you are monitoring a single link and is using windows then you can use PRTG. If you are monitoring a couple of devices and interfaces then you can use the opensource alternative like mrtg or rrdtool.
Configure your router/switch to allow accept snmp queries.
In global configuration mode,
router>en
router#config t
router(config)#snmp-server community
router#end
router#write mem
k0rg
