OUtbound ACL problem on ASA5505
Jul 17th, 2008
Here's an easy one for all you veterans. I'm new to firewalling and had an outbound access-list problem. If I wanted to block one of my workstations on the inside with ip 192.168.x.x address from reaching a specific external host (like a website) what would my syntax look like?
So far I have tried this:
access-list acl_out extended deny tcp host 192.168.x.x host x.x.x.x interface outside eq www
access-group acl_out out interface outside
I do these commands but then it just blocks everything on the inside from reaching the net. Can you help?
Overall Rating: 5 (1 ratings)
Marwan ALshawi Thu, 07/17/2008 - 19:50
remove the above ACLs
do it as follow
access-list 100 deny tcp host 192.168.x.x host x.x.x.x eq www
access-list 100 permit ip any any
access-group 100 in interface inside
this is based on ip address
and if you want to block it for spesific website by name not ip u have to use class-map,policy map awith regex a bit more complex
but for the ip based blocking do as i told u
and u got denied because there is implicit deny after each acl so u need to put the permit any any at the end
dont forget always when u block make the blocking as close to the source as posible so that apply the ACL on the inside interface in the inbound direction
good luck
Rate if helpful
dhananjoy chowdhury Thu, 07/17/2008 - 20:40
Try this :-
access-list acl_out deny tcp host 192.168.x.x host x.x.x.x eq www
access-group acl_out in interface inside
** Also make sure that this ACL is above the other ACL statements which are allowing the entire subnet to go to Outside.
007dan2008 Fri, 07/18/2008 - 08:36
I have not been able to try it out yet, I will perform the change after business hours tonight and try to respond afterwards. Thank you all for your suggestions!
007dan2008 Sun, 07/20/2008 - 11:52
Well it would appear that your thoughtful comments have paid off. I understand what was wrong. The acl you provided worked great and everything is up and running. Thanks again!
