%FIB-3-NOMEM: Malloc Failure, disabling CEF,
Jul 17th, 2008
My router is restarting with the following error
-Traceback= 0x154BD60 0x10519A0
HW details NGP G2
c7200p-adventerprisek9-mz.124-15.T1.bin
MPLS BGP is running this is PE router
Goutam Sanyal Thu, 07/17/2008 - 21:12
As per Cisco:
A memory shortage has caused an internal software error. CEF switching has been disabled on the specified slot.
Recommended Action: Enter the clear cef linecard slot command. Next, check the status of the line card by entering the show cef linecard command. If this message recurs, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://www.cisco.com/cgi-bin/front.x/case_tools/caseOpen.pl, or contact your Cisco technical support representative and provide the representative with the information you have gathered. Attach the following information to your case in nonzipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs. chnical support representative, and provide the representative with the information you have gathered.
You can visit the bellow CEF-Related Error Messages for troubleshooting,
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a0080110d68.shtml
Goutam
[Pls rate if it helps you]
Paolo Bevilacqua Fri, 07/18/2008 - 00:37
Hi, the IOS you are using has many bugs, for stable operation of 7200 I recommend use of 12.2S and nothing else.
Please rate post if it helps!
