ACE - Ping to Server-Side interface
Answered Question
Jul 17th, 2008
Hi Folks,
I have a problem whereby I need to allow my real servers to ping the Server-Side ACE interface. Is this explicitly denied? I have the VIP up and running OK but my server can't ping the Server-Side interface (which is it's gateway).
Thanks in advance,
SteveK.
Correct Answer by jleszewski about 8 years 10 months ago
I think You should apply policy REMOTE_MGMT_ALLOW_POLICY to interface vlan 56 or globally.
Currently it's only applied to vlan 55 which is the client side interface.
If You don't want telnet/ssh access from server side, then You need to prepare another class and policy with only icmp traffic allowed.
Correct Answer by Syed Iftekhar Ahmed about 8 years 10 months ago
Your management policy is not configured under server side vlan
Do the following and you are good to go
interface vlan 56
service-policy input REMOTE_MGMT_ALLOW_POLICY
Syed Iftekhar Ahmed
Overall Rating: 4.3 (3 ratings)
jleszewski Thu, 07/17/2008 - 23:26
You probably didn't configure management type policy or didn't include icmp traffic there.
Or didn't apply this policy to appropriate interface or globally.
stevek1 Thu, 07/17/2008 - 23:33
Thanks for the response Kuba.
I've attached the config for you - can you see what the cause is?
SteveK.
Correct Answer
Syed Iftekhar Ahmed Fri, 07/18/2008 - 00:19
  • Blue, 1500 points or more
interface vlan 56
Syed Iftekhar Ahmed
Correct Answer
jleszewski Fri, 07/18/2008 - 02:21
stevek1 Sun, 07/20/2008 - 19:50
Thanks Kuba and Syed,
Your speedy response was most helpful.
Cheers, SteveK.
