Strange BGP issue - not advertising BGP route
Answered Question
Jul 17th, 2008
Hi all
I have a strange BGP advertising problem and was hoping that someone might be able to give me an answer.
I run BGP on a Catalyst 3750 switch running Enh Image ver 12.2(25r)SE1. On this switch I've configured BGP v4 on it. A router at a remote office is advertising the following subnets: 10.109.3.0/24; 10.109.5.0/24; 10.109.10.0/24; 10.109.100.0/24 and 10.109.200.0/24 to this Cat3750 switch. It's able to receive all 5 subnets just fine but for some reason, it'll only advertise on the first 4 subnets and not the 5th one on 10.109.200.0/24. I checked the switch and this is what it shows:
#sho ip bgp 10.109.3.0
BGP routing table entry for 10.109.3.0/24, version 1627
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Advertised to update-groups:
192.168.157.1 from 192.168.157.1 (10.198.78.36)
Origin IGP, localpref 100, weight 100, valid, external, best
Extended Community: RT:17477:78
#sho ip bgp 10.109.200.0
BGP routing table entry for 10.109.200.0/24, version 1496
Not advertised to any peer
64900 64900
The statement "Not advertised to any peer" is clearly the reason for it to not advertise the subnet on to other iBGP peers. I've checked out the link http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800945ff.shtml but it doesn't fix my problem.
Attached is a cut down version of my config and also other show ip bgp xxx commands. Thanks in advance fro your help.
Correct Answer by Harold Ritter about 8 years 6 months ago
Vincent,
I would try using an outbound route-map instead of a distribute-list and see if the problem goes away.
Overall Rating: 5 (1 ratings)
arunsing Fri, 07/18/2008 - 00:55
Hi Vincent, There are a few bugs with the 12.2 IOS train that you are using related to BGP. Try clearing the bgp neighborship and see if that fixes the issue.
Harold Ritter Fri, 07/18/2008 - 08:58
Vincent,
Correct Answer
Harold Ritter Fri, 07/18/2008 - 09:01
Vincent,
vincent-n Sun, 07/20/2008 - 15:36
Thank you very much for your post. Implementing a simple route map together with a BGP soft resync has now fixed the problem. The command I used is 'clear ip bgp 10.95.3.19 soft out' just in case someone else is interested.
arunsing Fri, 07/18/2008 - 18:37
Yes I will agree. Infact using route-maps instead of distribute lists is a workaround.
