07-17-2008 11:22 PM
The following message appeared:
Execution Status : Job Execution Partially Successful for device
Execution Message : CM0057 PRIMARY RUNNING Config fetch SUCCESS, archival failed for 158.234.170.2 Cause: CM0002: Could not archive config Cause: Device may not be reachable, may be in suspended state or credentials may be incorrect. Action: Verify that device is managed, credentials are correct and file system has correct permissions. Increase timeout value, if required. Action: Verify that archive exists for device.
But I can download startup config from these two MSFCs:-( The credentials are OK and I tried to increase timeout but without success:-(
Can you help me, please?
Solved! Go to Solution.
07-18-2008 08:26 AM
It looks like the file system archive from this MSFC has been damaged. There are some missing files. Try deleting this device from RME, then re-add it. That should fix the problem.
07-17-2008 11:25 PM
You'll need to enable ArchiveMgmt Service debugging under RME > Admin > System Preferences > Loglevel Settings, then run a new archive sync for one of the failing MSFCs. Then post the dcmaservice.log.
07-18-2008 02:29 AM
07-18-2008 08:26 AM
07-23-2008 06:32 AM
thank you. The config is archived for now.
Roman
