pre-shared key length
robbhanMid
What is the maximum key length for a pre-shared key in a VPN setup and are all characters allowed?
andrew.prince
Level 10
Level 10
Robert,
The maximum PSK is 129 characters, I have used all types of characters before, with no issues.
HTH.
andrew.prince
Level 10
Level 10
Robert,
HTH.
It depends on what device are you using. Cisco allows any characters but Nortel for example does not support special characters, only alphanumerics.
Please rate if this helped.
Daniel
