Configure a default gateway on an AP in CLI
Jul 18th, 2008
Hi everybody,
I have gone through Cisco IOS Commands Master List, but I can't find the command line for assigning an IP default gateway on AP1130AG with IOS 12.3(8).
May you please help me ?
Thanks in advance !
AlexisGodinot Fri, 07/18/2008 - 04:02
It was actually very easy : need to enter it like it appears in the config.txt file.
In "configure terminal" mode :
ip default-gateway AAA.BBB.CCC.DDD
They probably omit to put it in the IOS Commands Master List.
