AnyConnect VPN on Cisco IOS router problem
Jul 18th, 2008
Hi all,
I am using a Cisco 871 IOS router with IOS software release 12.4(20)T (Adv.Security) and the following configuration for SSL VPN access.
aaa new-model
aaa authentication login VPNCLIENT local
aaa authorization network VPNGROUP local
crypto pki trustpoint TP-self-signed-1188774920
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1188774920
revocation-check none
rsakeypair TP-self-signed-1188774920
username remote privilege 0 secret xxx
interface FastEthernet4
ip address 192.168.32.125 255.255.255.240
interface Loopback10
ip address 192.168.32.142 255.255.255.240
ip local pool VPN-1 192.168.32.129 192.168.32.138
webvpn gateway webvpngw-1
ip address 192.168.32.125 port 443
ssl trustpoint TP-self-signed-1188774920
logging enable
inservice
webvpn install svc flash:/webvpn/svc_1.pkg sequence 1
webvpn context webvpncontext-1
ssl authenticate verify all
policy group webvpngroup-1
functions svc-enabled
timeout idle 3600
svc address-pool "VPN-1"
svc default-domain "home.loc"
svc keep-client-installed
svc dpd-interval gateway 30
svc rekey method new-tunnel
svc split include 192.168.32.0 255.255.255.128
svc split include 192.168.32.181 255.255.255.255
svc dns-server primary 192.168.32.109
default-group-policy webvpngroup-1
aaa authentication list VPNCLIENT
aaa authorization list VPNGROUP
gateway webvpngw-1
max-users 10
user-profile location flash:webvpn/webvpncontext-1/
logging enable
inservice
On the client side im using AnyConnect VPN Client version 2.2.0.133.
When I connect to the specified IP address (192.168.32.125) I've been asked for username and password. After successfull username/password
verfification I got the error message:
"An error was received from the secure gateway in response to the VPN negotiation request. Please contact your network administrator."
For troubleshooting I turned on the following debug commands.
debug webvpn tunnel
debug webvpn verbose
debug webvpn aaa
debug webvpn cookie
debug webvpn package
debug webvpn entry webvpncontext-1
You can find the output in the attachement
When the connection is closed - the debug shows the following message:
008305: Jul 18 11:35:21.940 CEST: %SSLVPN-5-SSL_TLS_ERROR: vw_ctx: webvpncontext-1 vw_gw: webvpngw-1 i_vrf: 0 f_vrf: 0 status: SSL/TLS connection
error with remote at 192.168.32.2:1823
If you have any idea, pleas let me know!
Many thanks!!!
Best regards
Peter
aghaznavi Thu, 07/24/2008 - 10:33
  • Silver, 250 points or more
1. Uninstalled and re-installed the webvpn package and the anyconnect package.
2. Assign the different pool for both ipsec and anyconnect clients.
