unity message checking from the out side -- configuration
Jul 18th, 2008
I want to configure one option in unity, If the users are sitting in the out side office, they want to check there voice mail. if anybody done the same configuration can you please replay to me
sunish
saz6710@cisco Fri, 07/18/2008 - 02:44
Sunish
Try alternate extension for that subscriber.
cheers
Shahid
tristan.delsol Fri, 07/18/2008 - 03:18
Hi Sunish,
You could create a routepoint and assign a dn to it. At the dn configuration select to forwardall to voicemail.
Then in Unity create a new Call Route and select forwarded calls. Fill in the dn you created earlier as the forwarding station and select Sign-In at Send Call to option.
Cheers,
