No translation group found
Answered Question
Jul 18th, 2008
I get the following error message when I try to connect over a site-to-site VPN:
No translation group found for tcp src outside: dst inside:
How do I set up the asa so that all traffic coming from gets properly translated and can travel the inside hosts on
My config:
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
ip address
interface Vlan3
nameif dmz
security-level 50
ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 3
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
dns server-group DefaultDNS
domain-name *
access-list http_access_in extended permit tcp any any eq www
access-list dmz_access_in extended permit icmp
access-list dmz_access_in remark Specify what kind of trafic should be allowed to travle to the inside network
access-list dmz_access_in extended permit tcp host eq www
access-list NO-NAT extended permit ip any
access-list ftp_access_in extended permit tcp any any eq ftp
access-list 8080_access_in remark Specify what kind of trafic should be allowed in. Don't forget the NAT
access-list 8080_access_in extended permit tcp any any eq www
access-list l2l_list extended permit ip
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-603.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list NO-NAT
nat (inside) 1
nat (dmz) 1
static (dmz,outside) tcp interface ftp ftp netmask
static (dmz,outside) tcp interface 8080 8080 netmask
static (dmz,outside) tcp interface www www netmask
access-group 8080_access_in in interface outside
access-group dmz_access_in in interface dmz
route outside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set FirstSet esp-3des esp-md5-hmac
crypto map abcmap 1 match address l2l_list
crypto map abcmap 1 set peer
crypto map abcmap 1 set transform-set FirstSet
crypto map abcmap interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 43200
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
tunnel-group type ipsec-l2l
tunnel-group ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map global_policy
Correct Answer by a.alekseev about 8 years 3 months ago
Overall Rating: 5 (1 ratings)
robbhanMid Fri, 07/18/2008 - 02:54
Oh! maybe I wasn't clear enough. is the outside interface of the other asa whos computers on its inside network needs to communicate with inside clients on this asa.
robbhanMid Fri, 07/18/2008 - 03:14
I have nat (inside) 1
on both my asa's. Is this correct?
Correct Answer
a.alekseev Fri, 07/18/2008 - 04:31
