Routing Between VLANS
Jul 18th, 2008
Hello -
I have a 3750 stack with routing enabled. I have two vlans, one for management and one for the office PCs. I can access the management from the switches if I telnet from one to another, but I am unable to access the switches via telnet from an office PC? I have done this before without any problems, but for some reason it is not working now. What could be the problem? Thanks
bvsnarayana03 Fri, 07/18/2008 - 04:21
  • Silver, 250 points or more
is the ping working from workstation vlan?
cacmk5 Fri, 07/18/2008 - 04:26
No ping doesn't work from the PC. Works from the switch.
Kevin Dorrell Fri, 07/18/2008 - 06:23
  • Green, 3000 points or more
Do your switches have a default gateway configured, so they know how to get to the PC VLAN?
By the same token, do the PCs have a default gateway configured?
Kevin Dorrell
Luxembourg
cacmk5 Fri, 07/18/2008 - 06:37
I have added the GW for the Management VLAN as well as the GW for the Office VLAN on the switches. If I connect into the Office VLAN GW, I can telnet from the core to the switches. The PCs are configured to route to the Office VLAN GW.
