ACE Module http POST limitations
Jul 18th, 2008
I have implemented a set of redundant ACE modules in Cat 6513s running virtual contexts. I was informed by the Notes administrators that they are only capable of POSTing 10MB through the ACE. I have checked and there seem to be no commands or parameters that indicate a http POST content limitation. The administrators need the POST limit to be 40MB.
Does anyone have any idea or does the ACE not limit http POST data at all (so the issue could be either on the servers or elsewhere on the network).
Much appreciated.
Gilles Dufour Fri, 07/18/2008 - 04:29
  • Cisco Employee,
There is no limit on the POST size for ACE.
You'll need to do some troubleshooting to see why if fails with bigger POST.
Sniffer traces of the failure and show tech captured before and after the problem.
Gilles.
