EPBX Remote Use
Jul 18th, 2008
Hi all i am using VOIP solution in a campus lan environment where all the VOIP Phones have EPBX as thier Gateway,and the EPBX is connected to PSTN for dialling outside,I have Public IP natted for the EPBX Gateway,can i use this Public IP any means in coordination with VOIP Software that sits on a Remote Home Computer user who uses Remote Access VPN for dialling purposes.....
please reply me as i am new to VOIP and need solution for my VPN
Overall Rating: 3 (1 ratings)
sreekanth sarma Fri, 07/18/2008 - 06:10
I am using ASA based remote Access VPN with AES and SHA , i dont know exactly about the EPBX as am new to campus i have to search for it , will it be possible?
