07-18-2008 06:05 AM - edited 07-03-2021 04:12 PM
How many simultaneous SSID can I configure on Cisco AIR-BR1310G ?
Thanks in advance.
Solved! Go to Solution.
07-19-2008 06:20 AM
Hi Roberto,
You can configure up to 16 SSIDs on your access point/bridge and assign different configuration settings to each SSID. All the SSIDs are active at the same time; that is, client devices can associate to the access point/bridge using any of the SSIDs. These are the settings you can assign to each SSID:
â¢VLAN
â¢Client authentication method
Note For detailed information on client authentication types, see "Configuring Authentication Types."
â¢Maximum number of client associations using the SSID
â¢RADIUS accounting for traffic using the SSID
â¢Guest mode
â¢Repeater mode, including authentication username and password
â¢Redirection of packets received from client devices
Hope this helps!
Rob
07-18-2008 09:32 AM
Not sure about the BR1310G, however I believe that the limit is 8 SSID's per AP. I have personally done 4 on a 1131G, but am not sure about the 1310G.
07-19-2008 06:20 AM
Hi Roberto,
â¢VLAN
â¢Guest mode
Hope this helps!
Rob
