Easy VPN on Cisco 857
hernan
I'm trying to connect two small offices via Cisco 857 routers. The main office's router is configured as EasyVPN Server and the other one, without static IP, as EasyVPN remote. The tunnel is already stablished and I can ping any machine in the main office from any machine in the remote one, but that's as far as I can get.
No other service works across the tunnel. I can't connect to the apache web server via http. I can't access the files in the file server either. As said before, ping is the only thing working. Any ideas?
6 Replies 6
husycisco
Level 7
Level 7
Hello Hernan,
Most probably it is an ACL issue. Running config of both sites would help us to determine the issue.
Thank you for your response.
I attach here both running configs.
Thank you very much again.
Hernán.
on the client
no access-list 1
no ip nat inside source list 1 interface Dialer0 overload
ip access-list ext NAT
deny 10.10.10.0 0.0.0.255 192.168.0.0 0.0.255.255
deny ip host 10.10.10.1 any
permit 10.10.10.0 0.0.0.255 any
ip nat inside source list NAT interface Dialer0 overload
Thanks for the help.
It didn`t solve the problem though...
I attach here the new client configuration. Server has not benn touched.
do you finally solve your problem ?
Well, actually I didn't. The hints given here didn't work and I have been quite busy with other matters lately.
Maybe after christmas I'll have some more time...
