GRE tunnel between 3560 and cisco 2801
Jul 18th, 2008
  • Gold, 750 points or more
Is GRE support on the 3560?
I will have two cisco ASA's between the 3560 and 2801 passing the GRE over IPSEC and also EIGRP traffic as well. is this possible? The plan is to route multicast PIM and multicast traffic across the GRE tunnel.
Overall Rating: 4.9 (9 ratings)
Edison Ortiz Fri, 07/18/2008 - 07:11
  • Hall of Fame,
    Founding Member
Yes, the 3560 supports GRE tunnels
Switch#sh ver | i IOS
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(25)SEC2, RELEASE SOFTWARE (fc1)
Switch#sh int | i Tun
Tunnel0 is up, line protocol is up
Hardware is Tunnel
Tunnel source 10.1.1.2 (Vlan1), destination 10.1.1.1, fastswitch TTL 255
Tunnel protocol/transport GRE/IP, key disabled, sequencing disabled
Tunnel TTL 255
HTH,
__
Edison.
Please rate helpful posts
a.alekseev Fri, 07/18/2008 - 07:29
Hi, Edison Ortiz
look at your sh ver
3550 and 3560 have different hardware.
Edison Ortiz Fri, 07/18/2008 - 07:36
  • Hall of Fame,
    Founding Member
Good catch. I just grabbed a CCIE rack w/o noticing the hardware.
Let me test in a 3560...
tdrais Fri, 07/18/2008 - 07:16
  • Blue, 1500 points or more
edit I was going to say not but they may have added support in a later release
Edison Ortiz Fri, 07/18/2008 - 07:35
  • Hall of Fame,
    Founding Member
Hi Tim,
I was able to configure but the documentation says otherwise:
Q. Does the Cisco Catalyst 3560-E support generic routing encapsulation (GRE) tunneling?
A. No. The Cisco Catalyst 3560-E can switch "transient" GRE tunneled traffic in hardware at wire rate, but it cannot act as a GRE tunnel endpoint. Future support of GRE tunneling in software is possible
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7078/prod_qas0900aecd805bacc7.html
Strange ...
___
Edison.
a.alekseev Fri, 07/18/2008 - 07:21
GRE is not supported on 3560 as well as on 3750. This is hardware limitation.
By the way GRE is supported in software on 3550.
Use a router instead.
francisco_1 Fri, 07/18/2008 - 07:29
Not sure why cisco would enable it on lower end switch like the 3550 and not on the 3560!
tdrais Fri, 07/18/2008 - 07:30
That makes more sense. I knew you could configure it on 3550 even though it very clearly says in the documentation that it is not supported. Never tried it on a 3560 since it says it is not supported and figured they patched it to not take the commands
sundar.palaniappan Fri, 07/18/2008 - 07:35
  • Green, 3000 points or more
Good catch there a.alekseev.
Deserves a '5' rating ;-) Have rated '5'
francisco_1 Fri, 07/18/2008 - 07:43
i also get the output below on my 3560!
switch#sh int | i Tun
Tunnel10 is up, line protocol is down
Hardware is Tunnel
Tunnel source UNKNOWN
Tunnel TTL 255
Edison Ortiz Fri, 07/18/2008 - 07:46
  • Hall of Fame,
    Founding Member
Hardware is Tunnel
Tunnel TTL 255
You need to specify the tunnel source and destination.
tdrais Fri, 07/18/2008 - 07:46
Sure does I tried it also. Even though the documentation clearly says it does not support the global command "interface tunnel"
Found this and I assume it applies to 3560 also
High CPU Utilization After Enabling GRE Tunnels
Generic Routing Encapsulation (GRE) tunnels are not supported on the Cisco Catalyst 3550 Switch. Even though the CLI commands are there to configure the GRE, it is not officially supported. Refer to the Unsupported VPN Configuration Commands section of Unsupported CLI Commands for Catalyst 3550 for this information. The reason for this is that the Cisco Catalyst 3550 Switch uses hardware-based Cisco Express Forwarding (CEF) switching. There is no method to CEF-switch GRE packets. GRE packets must be encapsulated by the software. The hardware does not have the capability to encapsulate the packets. Consequently, this traffic is processed or software switched. The process or software switched traffic can quickly cause the CPU to spike.
Edison Ortiz Fri, 07/18/2008 - 07:50
  • Hall of Fame,
    Founding Member
Good find Tim ! The problem is the feature is software driven hence not recommended or supported in 35xx.
__
Edison.
rsgamage1 Fri, 07/18/2008 - 07:58
  • Bronze, 100 points or more
So that's what FN says if you search by feature.
francisco_1 Fri, 07/18/2008 - 07:50
Hardware is Tunnel
Tunnel TTL 255
Edison Ortiz Fri, 07/18/2008 - 07:44
  • Hall of Fame,
    Founding Member
Verified with 3560s this time :)
Rack1SW2#sh ver | i IOS
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(25)SEE4, RELEASE SOFTWARE (fc1)
Rack1SW2#sh int | i Tun
Hardware is Tunnel
Tunnel source 150.1.8.8 (Loopback0), destination 150.1.7.7, fastswitch TTL 255
Tunnel TTL 255
Rack1SW2#sh run | be Tunnel
interface Tunnel0
ip address 9.9.9.2 255.255.255.0
tunnel source Loopback0
tunnel destination 150.1.7.7
Verify that multicast actually works
Rack1SW2#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Rack1SW2(config)#router eigrp 1
Rack1SW2(config-router)#net 9.9.9.2 255.255.255.0
Rack1SW2(config-router)#no aut
Rack1SW2(config-router)#end
Rack1SW2#
Rack9Pod1>1
[Resuming connection 1 to SW1 ... ]
3w
Rack1SW1#conf t
Rack1SW1(config)#router eigrp 1
Rack1SW1(config-router)#net 9.9.9.1 255.255.255.0
Rack1SW1(config-router)#end
Rack1SW1#
3w0d: %SYS-5-CONFIG_I: Configured from console by console
Rack1SW1#
3w0d: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor 9.9.9.2 (Tunnel0) is up: new adjacency
Rack1SW1#sh ip eigrp ne
IP-EIGRP neighbors for process 100
H Address Interface Hold Uptime SRTT RTO Q Seq Type
(sec) (ms) Cnt Num
1 183.1.107.10 Fa0/14 14 1w3d 1 200 0 494
0 183.1.17.1 Fa0/1 13 1w4d 1 200 0 618
(sec) (ms) Cnt Num
0 9.9.9.2 Tu0 14 00:00:15 764 5000 0 1
Rack1SW1#
rsgamage1 Fri, 07/18/2008 - 07:47
So how reliable is the Cisco FN in situations like this ?
a.alekseev Fri, 07/18/2008 - 08:01
try to forward traffic through the tunnel
Edison Ortiz Fri, 07/18/2008 - 08:10
  • Hall of Fame,
    Founding Member
Rack1SW1#show ip route eigrp 1
91.0.0.0/24 is subnetted, 1 subnets
D 91.91.91.0 [90/297372416] via 9.9.9.2, 00:00:33, Tunnel0
Rack1SW1#ping 91.91.91.2
Sending 5, 100-byte ICMP Echos to 91.91.91.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 67/70/76 ms
Rack1SW1#telnet 91.91.91.2
Trying 91.91.91.2 ... Open
User Access Verification
Password:
rsgamage1 Fri, 07/18/2008 - 08:11
Any impact on the CPU utilization?
Edison Ortiz Fri, 07/18/2008 - 08:14
  • Hall of Fame,
    Founding Member
I was routing 1 network.
I checked the CPU and showed no spike. Not sure how it would behave with a lot of traffic. Most likely, it will spike the CPU since packets will be processed switched.
Not a recommended solution but tunneling in the 3560 does work.
rsgamage1 Fri, 07/18/2008 - 08:20
So the point here is whether it is 'usable' or not?
As most of the documents clearly indicated it is not recommended/fully support for "some" reason(CPU,etc).
Is this a generic rule for Catalyst 2XXX and 3XXX?
Are there any exceptions?
Edison: As a NCE would you suggest that Netpros rely on Cisco Feature Navigator?
Edison Ortiz Fri, 07/18/2008 - 08:28
  • Hall of Fame,
    Founding Member
Right, the feature works but not recommended due to hardware limitation.
The problem is that Cat3xxx shares a lot of the code from regular IOS routers and while the commands are available, the feature does not work. It comes to mind some QoS commands and ip accounting. While you can enter the commands in the CLI, they do nothing.
On this case, the tunnel actually works and transport data. In a pinch, you can configure a tunnel with a 3560 but I wouldn't recommend such design in a production environment. Large amount of data via the tunnel can result in a denial of service on the switch.
The Feature Navigator is a solid search engine. With that said, there are a lot of Cisco products out there and there are times when all the features/services aren't incorporated in the tool. Best bet is to double-check a feature/service by looking at the product's Release Notes.
HTH,
__
Edison.
rsgamage1 Fri, 07/18/2008 - 12:41
Edison,
Great explanation !
Thanks for your valued thoughts and time..5+ :)
a.alekseev Fri, 07/18/2008 - 09:07
this is localy generated traffic...
Edison Ortiz Fri, 07/18/2008 - 09:37
  • Hall of Fame,
    Founding Member
interface Loopback91
ip address 91.91.91.2 255.255.255.0
interface Tunnel0
router eigrp 1
network 9.9.9.0 0.0.0.255
network 91.91.91.0 0.0.0.255
no auto-summary
Rack1SW2#sh ip eigrp neighbors tunnel 0
(sec) (ms) Cnt Num
0 9.9.9.1 Tu0 13 00:01:34 59 5000 0 3
Rack1SW2#
interface Tunnel0
ip address 9.9.9.1 255.255.255.0
tunnel destination 150.1.8.8
router eigrp 1
no auto-summary
Rack1SW1#sh ip eigrp ne tunnel 0
(sec) (ms) Cnt Num
0 9.9.9.2 Tu0 12 00:02:21 285 5000 0 3
Rack1SW1#
Rack1R1(config)#ip route 9.9.9.0 255.255.255.0 183.1.17.7
Rack1SW2(config)#ip route 183.1.17.0 255.255.255.0 9.9.9.1
Rack1R1#trace 9.9.9.2
Tracing the route to 9.9.9.2
1 183.1.17.7 0 msec 4 msec 0 msec
2 9.9.9.2 45 msec * 40 msec
Rack1R1#telnet 9.9.9.2
Trying 9.9.9.2 ... Open
Password:
Rack1SW2>
Rack1SW2#sh int tunnel 0
Hardware is Tunnel
Internet address is 9.9.9.2/24
MTU 1514 bytes, BW 9 Kbit, DLY 500000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel TTL 255
Checksumming of packets disabled, fast tunneling enabled
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/0 (size/max)
140 packets input, 11041 bytes, 0 no buffer
Received 0 broadcasts (86 IP multicast)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
128 packets output, 10944 bytes, 0 underruns
a.alekseev Fri, 07/18/2008 - 09:54
Edison Ortiz
thank you for your patience. 5 ponits :)
but could you add some device behind 3560?
Edison Ortiz Fri, 07/18/2008 - 10:28
  • Hall of Fame,
    Founding Member
Rack 1 Router will connect to 92.92.92.2 via Tunnel.
Router 1 is directly attached to SW1
Router 2 is directly attached to SW2
Router 2 is announcing 92.92.92.2 via OSPF
Rack1R2#sh ip os int bri
Interface PID Area IP Address/Mask Cost State Nbrs F/C
Lo92 1 0 92.92.92.2/24 1 LOOP 0/0
Fa0/0 1 0 183.1.28.2/24 1 BDR 1/1
Rack1R2#
Rack1SW2#sh ip route os
92.0.0.0/32 is subnetted, 1 subnets
O 92.92.92.2 [110/2] via 183.1.28.2, 00:01:44, Vlan28
Rack1SW1#sh ip route os
O 92.92.92.2 [110/11113] via 9.9.9.2, 00:02:01, Tunnel0
Rack1R1#sh ip route os
9.0.0.0/24 is subnetted, 1 subnets
O 9.9.9.0 [110/11112] via 183.1.17.7, 00:02:19, FastEthernet0/0
O 92.92.92.2 [110/11114] via 183.1.17.7, 00:02:19, FastEthernet0/0
Rack1R1#trace 92.92.92.2
Tracing the route to 92.92.92.2
2 9.9.9.2 36 msec 36 msec 44 msec
3 183.1.28.2 36 msec * 32 msec
Rack1R1#
Rack1R1#ping 92.92.92.2 repeat 100000
Sending 100000, 100-byte ICMP Echos to 92.92.92.2, timeout is 2 seconds:
Rack1SW1#show process cpu | i CPU
CPU utilization for five seconds: 7%/0%; one minute: 7%; five minutes: 7%
Rack1SW1#sh int tunnel 0 | i packets output
1061 packets output, 141750 bytes, 0 underruns
1075 packets output, 143682 bytes, 0 underruns
1090 packets output, 145752 bytes, 0 underruns
CPU utilization for five seconds: 8%/0%; one minute: 7%; five minutes: 7%
1213 packets output, 162692 bytes, 0 underruns
1259 packets output, 169040 bytes, 0 underruns
1321 packets output, 177562 bytes, 0 underruns
Rack1SW1#
___
This is it for me. I'm done testing.
