07-18-2008 06:43 AM - edited 03-17-2019 09:26 PM
Hi, I purchased 4 WIC-1AM cards for my cisco 1760 gateway to use with cisco call manager server. I'm trying to figure out if I can even use these cards for voice cards to make calls inbound and outbound. I'm seing that the cards that CM gives me are all VIC cards listed and i don't see any WIC cards listed in the endpoint list on the CM for the gatway. So can I even use these cards for what I'm trying to do??? Please help???
Solved! Go to Solution.
07-18-2008 07:52 AM
Hi, you cannot use these card for voice. These are Analog Modem cards and serve no other purpose than that.
Please rate post if it helps!
07-18-2008 01:21 PM
With a vonage sip account (or any other ITSP - Internet Telephony Service Provider) you connect via broadband doing some configuration on the router. You don't need any DSP module to do that.
With the analog line, you need a minimum of PVDM256K-4 else the fxo card alone won't work.
Sorry, but making right purchases for cisco gear require detailed knowledge.
07-18-2008 07:52 AM
07-18-2008 12:44 PM
Alright thanks alot p.bevilacqua :)
One more thing, im ordering new cards now, but I'm not sure which to get. Should I get the VIC-2FXO or VIC-2FXS? I'm just want it to work with my vontage line and my cisco 7970 phone we have? I know one recieves power and one sends power but I'm not sure which one I need in my case. Any thoughts???
07-18-2008 01:05 PM
Hi, if you upgrade to a "vonage sip account aka corporate", you can do without any card at all. It is not available through normal channels so you've to search a bit.
If going with the analog line, the card is vic-2fxo, but you also need DSP resource, that's another HW module, do "show diag" to see if you have anything already.
Thanks for the appreciation and good luck!
07-18-2008 01:10 PM
If i got the vontage sip account how would i hook it up to my CM Sever?
I'm using a 1760 gatway, what is a DSP resource?
When i do show diag I get this from my router:
show diag
Slot 0:
C1760 1FE VE 4SLOT DV Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 5.0
PCB Serial Number : FOC08077JDP
Part Number : 73-7167-05
Board Revision : B0
Fab Version : 04
Product (FRU) Number : CISCO1760
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 16 41 05 00 C1 8B 46 4F 43 30 38 30
0x10: 37 37 4A 44 50 82 49 1B FF 05 42 42 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Packet Voice DSP Module Slot 0:
Not populated
Packet Voice DSP Module Slot 1:
Not populated
WIC/VIC Slot 0:
One Port Modem WIC
Hardware revision 1.0 Board revision H0
Serial number 0034764142 Part number 800-08823-01
FRU Part Number WIC-1AM=
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
EEPROM format version 1
0x20: 01 38 01 00 02 12 75 6E 50 22 77 01 00 00 00 00
0x30: 88 00 00 00 06 02 10 01 FF FF FF FF FF FF FF FF
WIC/VIC Slot 1:
One Port Modem WIC
Serial number 0034764050 Part number 800-08823-01
0x20: 01 38 01 00 02 12 75 12 50 22 77 01 00 00 00 00
What do you think?
07-18-2008 01:21 PM
07-18-2008 01:26 PM
Thanks a bunch p.bevilacqua, you've been a great resource in my VOIP quest :) I'm just going to buy the VIC-2FXO and give it shot. I'm sure we will be in touch soon. Once again thanks a bunch. I owe you one.
07-18-2008 01:31 PM
No sweat. Thanks again and good luck!
