Need to find out what has been modified to running-config
Jul 18th, 2008
When I enter the "reload" command, Cisco ASA 5510 asks me
a question: System config has been modified Save? [Y]es/[N]o:
All I did was issuing a few "show" commands before the "reload" command. I definitely need to find out what
has been modified before the reboot
Is there any way to find out what has been modified to the running configuration.
Thanks!
If you want to know when changes are made, but don't want to setup TACACS (and you have a syslog server setup), you can have the router syslog all commands entered while in config mode:
devcorert01#conf t
devcorert01(config)#archive
devcorert01(config-archive)#log config
devcorert01(config-archive-log-cfg)#hidekeys
devcorert01(config-archive-log-cfg)#logging enable
devcorert01(config-archive-log-cfg)#notify syslog
Anytime someone enters any command while in config mode, the command will be sent to your syslog server.
Examples:
Jul 21 10:15:41 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:console logged command:do sh run
Jul 21 10:17:33 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:console logged command:interface GigabitEthernet2/2
Jul 21 10:17:38 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:console logged command:shutdown
Jul 21 10:17:42 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:console logged command:no shutdown
Note the "do show run". Even thought that is not a config command per se, it was entered while in config mode. Also notice the user is "console". If it was from a telnet session, you would see
Jul 21 10:17:33 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:unknown user logged command:interface GigabitEthernet2/2
Jul 21 10:17:38 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:unknown user logged command:shutdown
Jul 21 10:17:42 EDT: %PARSER-5-CFGLOG_LOGGEDCMD: User:unknown user logged command:no shutdown
Mike
michael.leblanc Mon, 07/21/2008 - 07:25
Enter the following on the CLI:
show archive config differences nvram:startup-config system:running-config
Lines preceded with "+" are only found in the running-config. Lines preceded with "-" are absent from the running-config (i.e.: only found in the startup-config).
Jagdeep Gambhir Tue, 07/22/2008 - 05:29
In ASA if you are doing tacacs command accounting then it will logs only those command that change the running config.
Since show command do not change any config , so it won't be reported by tacacs.
~JG
michael.leblanc Tue, 07/22/2008 - 10:44
Re: My post above.
Lost sight of the fact that you were using an ASA. Sorry about that.
... would be useful on an IOS device.
