Can FXO perform an auto-dial?
Answered Question
Jul 18th, 2008
Hi-
I've been trying to work on this issue for a while. I have my VIC2-4FXO port connected to POTS (let's say the number is 200-1111).
If I dial 200-1111, I'll hear a second dial tone and can call anyone without problems thru this router.
But what I wish to do is when I call 200-1111, my 2801 router will automatically dial a pre-set number. Will this be even possible?
Thanks.
Correct Answer by paolo bevilacqua about 8 years 10 months ago
Under voice-port:
connection plar opx
Please rate post if it helps!
Overall Rating: 5 (3 ratings)
robertdm1973 Fri, 07/18/2008 - 09:06
I forgot to mention that the FXO is connected to an analog service, thus no DID or DNIS coming form the carrier. Any ideas?
Correct Answer
paolo bevilacqua Fri, 07/18/2008 - 12:19
  • Hall of Fame,
    Founding Member
Under voice-port:
connection plar opx
Adrian Saavedra Fri, 07/18/2008 - 12:20
  • Gold, 750 points or more
Hi friend,
You can use the connection plar command under voice-port to route calls to a predefined extension.
Hope this helps.
- Adrián.
robertdm1973 Fri, 07/18/2008 - 13:08
Yeah , PLAR fixed my problem.
Here's an ace for you!
Thanks.
