dhananjoy chowdhury Sat, 07/19/2008 - 01:21
It depends on your network setup, it could be a point 2 point GRE tunnel or IPSEC.
But if you setup a GRE tunnel over a Pulic network use IPSEC over it for encrytion.
jasosan22 Sat, 07/19/2008 - 08:40
It is a Fonality VOIP server (softswitch) In order to configure the phones initually they need to be on the same segment. I haven't got the exact details but it's probably some kind of bootp type deal. The softwitch is in Chicago. Main office is in New Orleans. I was going to purchase two 851 routers to set up a tunnel between the sites to configure the phones.
Marwan ALshawi Sat, 07/19/2008 - 01:31
u need to run site to site vpn in network extention mode
if u need to use routing protocol or multicast over the vpn
then u need to use gre over ipsec
otherwise only ipsec enough
if u need more details, just ask
good luck
rate if helps
