TCP Window Size
Jul 18th, 2008
When downloading files from a server that connects via an SSL connetion terminated on CSS, we're seeing very slow download time. When we bypass the CSS and terminate the SSL connection directly on the server, downloads are approx. 5X faster.
The server has a TCP window size of 65535, can TCP windows be adjusted on a CSS for that particular service or content rule. What's the default TCP window size ?
Thanks.
Manjit.
Overall Rating: 4.5 (2 ratings)
mduhra Mon, 07/21/2008 - 07:55
Hi Syed,
Thanks for the link, it was very helpful...
One more thing, this is a snapshot of my SSL Proxy List config, can you let me know if you think it'll work. Especaially the TCP window size commands, does the order/placement matter here ?
ssl-proxy-list SSL1
ssl-server 1
ssl-server 1 rsakey INFO-test
ssl-server 1 rsacert INFO-test
ssl-server 1 vip address 10.10.55.10
ssl-server 1 cipher rsa-with-rc4-128-md5 10.10.55.10 88
ssl-server 1 tcp server window 40960
ssl-server 2
ssl-server 2 vip address 10.10.55.12
ssl-server 2 cipher rsa-with-rc4-128-md5 10.10.55.12 88
ssl-server 2 rsakey INFO-test-admin
ssl-server 2 rsacert INFO-test-admin
ssl-server 2 tcp server window 40960
ssl-server 1 urlrewrite 1 *
ssl-server 2 urlrewrite 2 *
ssl-server 1 ssl-queue-delay 0
ssl-server 2 ssl-queue-delay 0
ssl-server 1 tcp virtual nagle disable
ssl-server 2 tcp virtual nagle disable
ssl-server 3
ssl-server 3 rsakey INFO-test-su
ssl-server 3 rsacert INFO-test-su
ssl-server 3 vip address 10.10.55.14
ssl-server 3 cipher rsa-with-rc4-128-md5 10.10.55.14 88
ssl-server 3 urlrewrite 3 *
ssl-server 3 ssl-queue-delay 0
ssl-server 3 tcp virtual nagle disable
ssl-server 3 tcp server window 40960
active
Syed Iftekhar Ahmed Mon, 07/21/2008 - 15:18
Use the following lines in your ssl services.
ssl-server <#> tcp server window 40960
ssl-server <#> tcp virtual window 40960
If it doesnt improve performance
try disabling the Nagle algorithm and setting the SSL Ack delay to
zero.
ssl-server 10 tcp virtual nagle disable
ssl-server 10 ssl-queue-delay 0
Syed
