PIX Remote Access VPN
Jul 18th, 2008
I have setup a PIX 515 running v803 for remote access from a VPN client. I cyrrently have site-to-site VPN's which have been setup and work fine. Currently, when i connect using the VPN client (v5), although Phase 1 completes Phase 2 does not, I just get IKE negotiation failed.
crypto dynamic-map vpnmap_dynmap 5 set transform-set TRANS_ESP_3DES_MD5
crypto dynamic-map vpnmap_dynmap 15 set transform-set ESP-3DES-SHA
crypto dynamic-map vpnmap_dynmap 30 set transform-set ESP-DES-MD5
crypto dynamic-map vpnmap_dynmap 40 set transform-set ESP-DES-SHA
crypto dynamic-map vpnmap_dynmap 50 set pfs
crypto dynamic-map vpnmap_dynmap 50 set transform-set ESP-3DES-SHA
crypto map vpnmap 65535 ipsec-isakmp dynamic vpnmap_dynmap
crypto isakmp enable outside
crypto map vpnmap interface outside
group-policy client_vpn_access internal
group-policy client_vpn_access attributes
vpn-tunnel-protocol IPSec
dns-server value 10.1.1.1
tunnel-group client_vpn_access type remote-access
tunnel-group client_vpn_access general-attributes
default-group-policy client_vpn_access
address-pool client_vpn_access
tunnel-group client_vpn_access ipsec-attributes
pre-shared-key presharedkey
#### Log from Cisco VPN Client v5 ####
445 21:12:12.686 07/18/08 Sev=Info/4 CM/0x6310000E
Established Phase 1 SA. 1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
467 21:12:12.766 07/18/08 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:NO_PROPOSAL_CHOSEN) from x.x.x.x
470 21:12:12.766 07/18/08 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=29790EF2FE6728A8 R_Cookie=D4C90BEBCF7838BE) reason = DEL_REASON_IKE_NEG_FAILED
545 21:46:40.379 07/18/08 Sev=Info/4 CM/0x63100012
Phase 1 SA deleted before first Phase 2 SA is up cause by "DEL_REASON_IKE_NEG_FAILED". 0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
Please can you help.
Overall Rating: 5 (1 ratings)
a.alekseev Fri, 07/18/2008 - 13:01
  • Gold, 750 points or more
deb crypto isakmp 10
deb crypto ipsec 10
srue Fri, 07/18/2008 - 19:02
  • Blue, 1500 points or more
please post your isakmp policies
sh run all isakmp
bjssccouser Sat, 07/19/2008 - 02:02
crypto isakmp identity address
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 10
encryption des
hash md5
group 1
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 28800
crypto isakmp policy 40
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp policy 60
encryption 3des
hash md5
group 1
lifetime 86400
crypto isakmp policy 80
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
a.alekseev Sat, 07/19/2008 - 06:39
no crypto dynamic-map vpnmap_dynmap 5 set transform-set TRANS_ESP_3DES_MD5
no crypto dynamic-map vpnmap_dynmap 15 set transform-set ESP-3DES-SHA
no crypto dynamic-map vpnmap_dynmap 30 set transform-set ESP-DES-MD5
no crypto dynamic-map vpnmap_dynmap 40 set transform-set ESP-DES-SHA
and show me your transform-set ESP-3DES-SHA
bjssccouser Sat, 07/19/2008 - 11:28
I have removed the dynamic crypto maps as above, which has resulted in the Cisco VPN client now connecting.
However, I had to also remove pfs as I am also using the PIX for L2TP/IPSEC VPN from a Windows client.
Could you explain why this wasn't working before? Shouldn't the VPN client have been presented with all the SA options and picked the one that suited it?
