CSM Modules and Server availability project
Jul 18th, 2008
I have 2 geographically separated sites, site A in the main office and site B is the Disaster recovery office. These 2 sites are connected by a high speed Layer 3 link (10Gb), The goal is to have duplicate servers available in site B in the event of partial server failure in site A or even complete failure of site A. Can I accomplished this with the CSM modules given that these servers will be in different networks and overall how would this configuration work, I really appreciate it.
Overall Rating: 5 (1 ratings)
Syed Iftekhar Ahmed Fri, 07/18/2008 - 14:17
  • Blue, 1500 points or more
Are you planning to put CSMs in both data centers or a single data center?
If CSM will be at one site (site A) only then
You need to use source NAT on CSM (Assumption: its in Site A) to make sure that the return traffic from servers in "site B"
can go back to the client through CSM at "Site A"
If both Data centers will have their own CSM modules then the best approach is to use GSS or any any Geo redundant setup that can check the load/health/availability/proximity of the VIPs (virtual ips configured on each CSM) in each data center and direct the clients intelligently to the appropriate data center.
Syed Iftekhar Ahmed
