CUCM 6.x with Panasonic TD500
Jul 18th, 2008
Hi everybody, i have to realize a integration between CUCM 6 and Panasonic TD500 , someone have experience in this kind of integration for help.
thanks a lot.
paolo bevilacqua Fri, 07/18/2008 - 13:53
  • Hall of Fame,
    Founding Member
Do you have ISDN PRI or BRI cards on the PBX? That is the very first requirement for integration.
The second one is the PBX technician willing to configure it to send calls to CM as needed.
Unfortunately they often are not very collaborative when a competitor enters their turf.
cvicentep Fri, 07/18/2008 - 14:08
In the PBX i have Pri30 cards where put the E1.
The PBX is used for the call center and its interacts with the CM.
