Joe Clarke Fri, 07/18/2008 - 14:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Sure. You can export a full User Tracking end host report to a CSV or PDF file from the GUI. Just run the report, then click the export icon at the top right-hand corner. If you want to export to CSV from the command line do:
NMSROOT/campus/bin/ut -cli -u USER -p PASS -query all -export FILENAME
Where USER is your LMS username, PASS is your password, and FILENAME is the file to which you want to export.
To export to XML, use the command:
cmexport ut -u USER -p PASS -host -query all -f FILENAME
